Toiselta foorumilta löydettyä: Laki Ranskassa 1.7.-12 alkaen
Harri Hemmilä
Pyörä: R1200GS
Lainattua tekstiä:
1.7. alkaen ajoneuvosta löydyttävä alkometri Ranskassa ajettaessa
Ranskassa astuu 1.7.2012 voimaan laki, jonka mukaan moottoriajoneuvossa tulee olla käyttämätön alkometripakkaus. Lokakuun 2012 alusta alkaen puhalluskokeeseen tarvittavan välineistön puuttumisesta sakotetaan.
LNE:n sivuilta löytyy listaus NF X 20-702 -standardin täyttävistä puhalluskoepakkauksista: http://www.lne.eu/en/certification/c...-companies.asp
IRU:n alkuperäinen englanninkielinen tiedote:
FNTR, France has informed us that according to the French breath test law of 28 February 2012 issued on 1 March 2012, from 1 July 2012 all drivers of any motor vehicle, excluding mopeds, will need to carry an unused breathalyser kit.
Enforcement of an €11fine for non-compliance to this measure will start on 1 November 2012.
The breathalyser kit must meet certain conditions, notably the expiration date set by the manufacturer.
In order to abide by this measure, drivers must:
• carry an unused breathalyser kit, available immediately and conforming to the NF X 20 702 standard for chemical breathalyser tests and the NF X 20 704 standard for electronic breathalyser tests. Breathalyser kits meeting these French standards are not solely manufactured and sold in France. A list of certified companies carrying the NF label of breathalyser kits is available on the LNE website – www.lne.eu
• stay within the legal blood alcohol limit of 50mg per 100ml of blood. Anyone driving in France must ensure that the breathalyser kit they are carrying is calibrated to the French legal limit.
Authorities will not ask drivers to use their own breathalyser kit to test their blood alcohol level. Should a driver be required to submit to a blood alcohol test, authorities will use their own material.
Voiko pitää paikkansa?
Tuffe
Pyörä: XTZ750
Re: Toiselta foorumilta löydettyä: Laki Ranskassa 1.7.-12 al
Viesti Kirjoittaja Tuffe »
Voi pitää paikkaansa. En kyllä ymmärrä miksi moista vaaditaan. Ehkä joku taho on löytänyt markkinaraon ja päässyt saunottamaan päätöksentekijöitä.
Ei siis kuitenkaan koske tätä kesää, ku sakottaminen alkaa vasta marraskuussa.
Kurahousu
Ei sitä kyllä mahdollisen 11 euron sakon takia ala mitään lisärompetta taskussa kantamaan...
Harri Hemmilä
Pyörä: R1200GS
No ei, nuo alkometrit joutuu kuitenki tilaamaan ulkomailta niin tulee halvemmaksi maksaa sakko...
dq
Viesti Kirjoittaja dq »
Aika näppärä asetus noin ranskalaisia ajatellen. Nyt löytyy autosta alkometri niin näkee ennen rattiin hyppäämistä onko tullut juotua liikaa, ei hemmetti mutta jos nyt tämän käytän ja lähden ajamaan niin saan sakot, enpäs puhallakaan.. :lol:
Peltsi
Viesti Kirjoittaja Peltsi »
Eikös jossain MP - maailmasa vai mikä lie ollu sen tyylistä juttua että sielä tulee joku huomioliivi pakko kans voimaan. Vai olikohan se vasta uhkailun tasolla.
Hyviä pykäliä. Vaan ei oo omaan elämään vaikuttavia ennenku Ruotsisa tulee voimaan tuommosia. Koska sen tietää että kohta sen jälkeen ne on tääläki.
Å
Pyörä: Liian monta
Viesti Kirjoittaja Å »
Alkometripaketti - Ranskassa :lol: Ahh... ne ranskalaiset...
Miten tää oikein menee...
Jarmo H
Pyörä: KTMs
Viesti Kirjoittaja Jarmo H »
Taitaa olla paikallinen "cost cutting" eli poliisilla ei ole omia alkometrejä riittävässä määrin. Sinänsä nerokas ajatus, mielikuvituksella ei ole rajaa jos aletaan soveltamaan Suomessa. Jos EU vaatii niin ollaan varmaan ensimmäisten joukossa.
Blugi
Pyörä: 950 Adv, 450 EXC-R
Viesti Kirjoittaja Blugi »
Pitääköhän ne ajoneuvossa lain mukaan mukana olevat huomioliivitkin kiikuttaa pollarille pysäytys tilanteessa, ettei konstaapeli jää auton alle :)
Pieni punnerrus siirtymällä tekee hyvää.
MarkkuHoo
Pyörä: BMW R80GS Finnduro -90
Peltsi kirjoitti:Eikös jossain MP - maailmasa vai mikä lie ollu sen tyylistä juttua että sielä tulee joku huomioliivi pakko kans voimaan. Vai olikohan se vasta uhkailun tasolla.
Ranskassa on ainakin autoissa ollut jo 2008 lähtien pakollista olla yks huomioliivi mukana. Tommosia autoja koskevia liivipakkoja on muistaakseni myös Itävallassa ainakin, ja Epsanjassa, ja mitänäitä oli. Sieltä ne tullee pikkuhilijaa...
Viesti Kirjoittaja Syke »
Ja kuinka monella Tallinnan kävijällä on se pakollinen jauhesammutin mukana...?
Edit. siis nelipyöräsessä.
Braa-aab!
THA
Pyörä: Yamaha ja TM
Viesti Kirjoittaja THA »
Ei tullu kun 700km Virossa viikko sit, enpä tienny mistään sammuttimesta. Myykö paikallinen poliisi "sopu"hintaan jos sattuu puuttumaan, vai viekö kilvet vai tuleeko vana iso sakko?
- tieto vähentää tuskaa
- TM 100jE "rin-tin-tin"
ollka
Pyörä: R1200GSA
Viesti Kirjoittaja ollka »
Huomioliivipakko on tulossa Ranskaan ensi vuonna. Siis ei vielä voimassa. Sen sijaan huomiohihanauha on jo käyttövaatimuksena siellä.
Rässi66
Pyörä: Honda CR250R
Viesti Kirjoittaja Rässi66 »
ollka kirjoitti:Sen sijaan huomiohihanauha on jo käyttövaatimuksena siellä.
Käykö vaarin vanha sähköasentajan(?) hihanauha, tuplasalamoilla?
Hyvin oli kuulemma huomattu Ranskassa aikonaan ja tietä saatu.
jaa
Pyörä: Paree ettei näy, ettei leimata
Viesti Kirjoittaja jaa »
ollka kirjoitti:Huomioliivipakko on tulossa Ranskaan ensi vuonna. Siis ei vielä voimassa. Sen sijaan huomiohihanauha on jo käyttövaatimuksena siellä.
No jos siis ihan tosissaan ollaan, niin siis mikä huomiohihanauha?
